Does anyone know where abouts the connection for the radiator fan is on a '99 Sei? I can see 2 wires that go near to the fan, one is possibly going into the engine near the oil filter, but I can't be sure... The other one is on the drivers side, coming down from above and underneath the arch liner...
Basically the problem is that the fan is not cutting in when the engine gets hot... So it's overheating... I've flushed out the system (radiator and engine)... I've replaced the thermostat too. Just now I've taken the wire going into the temperature sensor/radiator switch off and connected the two contacts together (as it says in my Cinq haynes manual) but the fan did not come on at all... I'm wanting to run a 12V supply to the fan to see if its actually working itself...
If it's not that, does anyone have any ideas as to what it could be?
Adam
Adam
