there is a set bit on the cable where you need to clip it on the stick, so the push-down engage works.
I don't think there is any adjustment at all.
If you want to rule out the cable, you could take the cable out the gearbox end too. Then reverse just slots in without pushing the stick down.
Ming
Yeah I tried removing that but I lost 5th? Do I just unscrew the cable from the gearbox end and leave on the bracket?
