orey
Hey all
i have slight problem the plastic bush that hold the gearstick down on my seicento has now completely broken up into pieces,
my only concern is how i remove the ball joints from the gearstick and the lever connected to the plastic block as i have looked through the technical manual it try an get an idea on how to remove and refit and it only shown the gearstick that has a lift up reverse,
ill be contacting fiat in the morning to get a replacement plastic block my other concern is that the lever that connected to the plastic block will not be supplied and will have to change them over is there a specific way in which it needs to be done. the lever i'm concerned about is the one that labeled 4
Many Thanks
Orey
Many Thanks
Orey
