Technical Washer pump which is which?
Hi, hopefully one of you clever people will tell me which washer pump is which on a SPI seicento? Without me getting under there and removing things ;)
James
If it was MPI it would be easier as there's only one pump.
SPI have two visually identical pumps. One does the front one does the back.
Incidentally it's the back one that's not working but when i get to the washer the battery will have been removed so can't test although i suppose i can follow the hoses to see where they go :rolleyes:
if the front one is working, just swap the plugs over and test to see if it is working?
Some one may have swaped any two off the cable plugs, or the pumps or the hoses.
And the factory may not heve been too careful....
Noel
