Pink192
Cinquecento Heater Switch problem:
when the slide switch is in the off position(Off) - the blower does not run
Correct and OK
when the slide switch is in the frist position(Slow) - the blower does not run
Not Correct and Not OK
when the slide switch is in the second position(Med) - the blower does not run
when the slide switch is in the final position(Fast) - the blower does run fast
Correct and OK
Please advise where the problem may lie, thanking you in advance.
Correct and OK
Correct and OK
