hi all,
as you may know i have been turbo converting my punto mk2 1.2 8v MPI FIRE engine
basically i have everything sorted all i have to do is wire the MF2 up to control the extra fueling
i am going to use 4 stock injectors on the rear off the inlet and need the MF2 to work all 4 i know it has been done before but need help with the wiring please...its only about 8 wires but any help at all is much much appreciated
i will be running 3D mapping with an additional 3 bar MAP sensor instead off the pressure sensor
RED - 12V power supply switched 5amp fused
DO i connect this directly to battery positive supply with a 5 amp fuse or does it need to be on an ignition live so it only come to life when ignition is on?
RED/BROWN - Red is 12V power supply and brown is injector drive
well 2 wires obviously come from the injector plug but which goes to which? theres a thick brown/white one and a thin green one on punto MPI injector plugs so unsure which to connect to
ORANGE/BLUE - Pressure ssensor (i wont be using as im using a 3 bar MAP sensor) ORANGE is 5v regualted supply and blue is signal wire
Do i just use these 2 wires on the 3bar map sensor? the map sensor is off an escort cosworth which has 3 pins as ususal im guessing one 5v positive, one signal and one earth am i right?? if so how do i know which is which?
YELLOW - RPM signal from coil
I dont have a negative from coil as well i dont run an old coil obvs i have twin coil pack so do i just use the cranksensor?? if so which wire do i connect to?
WHITE/BLACK
EARTH i got this one haha
any help is soo much appreciated as the car is off road now awaiting the installation off this
BTW this is the 3 bar MAP sensor im guessing that the third pin is earth as it has the metal plate coming from it so i will have to earth the body off the MAP sensor??
sorry for all the questions im just unsure and want to get it right first time
cheers in advance to anybody that helps
brin
WHITE/BLACK
brin
