Technical gearbox problems & another
spookycinq
Member
aylesbury buckinghamshire
Hi, i`ve got trouble putting my cinq into any gear & when its in gear feels like not secure in gear (gear stick really moves about) Any suggestions???
Also the fan doesn`t cut in so need another fan, but earlier today i see a puddle on the floor, i looked underneath the bonnet & it seemed like water was coming out of something underneath the exhaust manifold, anyone got an idea of what it could be??
Its a 1.1 sporting '94'
Thanks in advance
Thanks in advance
might not be the fan could well be the thermostatic fan switch in the radiator just above the bottom hose.disconnect the wiring and put a piece of wire across the connections see if the fan kicks in...if it does its the switch in the rad that needs replacing.
the water leak from under the exhaust is going to be either a core plug has gone or the pipe running from the back of the water pump is leaking either the rubber seal or its got a pin hole in it.
as for the gears not come across it but im sure someone else has:D
been thinking about sloppy gear lever...are the clips holding the cables in place on the gearbox??? check them there should be one on each cable(y)
