Well its finally started.....thought i would start at the easy end and work my way forwards.The rear beam is now out and stripped down to its component parts.
parts going into rear end are handbrake cable,rear drums,cylinders,brake shoes,fitting kit,rear wheel bearings and redo the poly bushes and get everything cleaned and painted up.
the whole of the underneath is getting waxoiled although everything is good underneath just extra protection
I know that the rear brakes are non exsistent as it is and and the passenger side needs a bearing so may as well do them both as no point in cutting any corners.
again a brake back plate has rotted out so both will be getting replaced.when undoing one of the rear brake pipes i literally just touched it and it snapped so good job i chosen to do the rebuild now as it could of been interesting to say the least coming into a roundabout
more pics and updates will follow as it progresses but this is not going to be done in a hurry
