taake the actual pump apart. there is a little gold sort of bottle like thing about 3-4 inch long. thats the pump. just swap that into your cinq one. and all is well, this way you dont need to use all the p75 crap that wont fitr the cinq.
its got a black pipe coming out the top of the gold thing, and is inside the bottom of the p75 pump, you will need to diss-assemble it. there not easy to get out but ive done a few so definatly possible
cinq one...
see the gold thing needs replacing (one lying on table)
on the punto ones and indeed the seicento ones its inside the actual pump, so follow the pipes and it will be there, not too hard to replace but be careful not to break anything
the little canister things are identical in all fiat pumps iirc. just the big fat black pipe coming out then a big and small spade on top. it will fit dont worry just needs the pipe going on and the two spades
either way the pump has a positive and negative, all it does is receive a signal and turn on or off, so any of them will fit in there as there simple contections... lets see how yours looks atm.
why are you changing it anyways??? was it working before?
kk, what ecu are you using? is the code light going off ect as the immob could be stopping the pump working.
u know the original pump will power a p75though with no troubles.
