Old 20-03-2011   #1
Angry alarm problems
just recently got a seicento that had been sitting in a garage for several years and the battery is dead, after charging the battery and putting it back in the car as soons a turn the ignition the alarm is set off and cannot be stopped , how do i go about fixing this?
thanks
scott
shoxik is offline Reply With Quote Quote
Old 20-03-2011   #2
Trader Rating: 1
cc1 has donated!
Re: alarm problems
Quote Originally Posted by shoxik View Post
thanks
scott
Find and remove the alarm fuse until you can get more info on the alarm.
Thanks shoxik thanked for this post
cc1 is offline Reply With Quote Quote
Old 21-03-2011   #3
Cinq/Sei Section Mod
Eklipze3k's Avatar
Eklipze3k has donated!
Eklipze3k is an honorary friend of the forum :)
Re: alarm problems
They don't come with alarms as standard so as cc1 says, find and remove the fuse to disable it and then find out what make/model it is and search for a user manual (google).
Eklipze3k is offline Reply With Quote Quote
Old 21-03-2011   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: alarm problems
Drop test the battery and make sure the earth connections are all intact, clean and tight.
The alarm could be seeing a voltage drop enough to set it off.
Chers
D
Old 21-03-2011   #5
Re: alarm problems
thanks will the fuse for the alarm be in the main fuse box or in a seperate one?
thanks
scott
Old 21-03-2011   #6
Re: alarm problems
You'll probably have to trace the wires back because of it being aftermarket it could be anywhere. I'd expect an in line fuse to be there or for it to share a fuse with something else
the invader: http://www.fiatforum.com/members-motors-non-fiat/270284-its-ford.html#post2762950
Quote Originally Posted by The Unknown View Post
IV Seen Bigger
Come to the darkside. We have cookies !
dronenrs is offline Reply With Quote Quote
Old 21-03-2011   #7
Re: alarm problems
ok thanks for your help il let you no how i get on
Old 21-03-2011   #8
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: alarm problems
It all depends on who installed the alarm and how sensible they were thinking.
If the alarm can be switched off by simply removing a fuse, then if they were thinking straight, the fuse will be well hidden.
I would be tempted to download the wiring diagram and remove all the alarm wiring and reinstate the original, unless you can quickly get a handle on how its been wired.
D
Old 21-03-2011   #9
Re: alarm problems
the problem is i dont have the manuel for the alarm so i haave no ides where and what it is
Old 21-03-2011   #10
Re: alarm problems
i have found the fuses and pulled them out and the engine would turn over, i left the car to go have lunch and when i come back the alarm was going off again when i tried to turn the car on . i have now bought i new battery and have the same problems :@
Old 21-03-2011   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: alarm problems
Start tracing the wiring with the car wiring diagram and remove it.
D
Old 22-03-2011   #12
Re: alarm problems
thanks iv sorted it out and the car is running fine now
thanks
scott
Alarm Problems steveo4245 Security 16 28-04-2011 22:44
alarm problems wilko1992 Security 0 21-02-2011 17:27
(G) alarm problems! jamie_hlx Bravo / Brava 2 28-03-2008 19:41
new alarm problems scottc1088 Security 10 29-12-2005 15:31
More Alarm problems Fournil Security 1 07-01-2004 23:07
