RuiG
Member
Hello all.
It's been a while since I posted something but on the positive side I feel more Cento Fanatic than ever. I now own 2 Cento Sportings
I've been a Cento Sporting owner for 4 years now, it has 170.000km on the clock and apart from head gasket gone, no other serious issues so far... it just drives and goes like hell.
Now I've purchased another Cento Sporting... it's a clone from my first one. It's black, 1996, also an airbag version and pretty much the same apart from the aircon my first one has. 120.00km on the clock and MOTed on the day I purchased it. Clean MOT apart from a re-inspection after CO failure (new lambda did the trick, previous owner payed for it)
Now the issue:
-When stepping on the clutch for a roundabout (from 4th to 3rd or 3rd to 2nd), revs drop a lot if I'm not fast enough to pick up the pace. It has cut-out some times so far and seems to get worse if the petrol is getting near the reserve.
-Idles at good revs, runs smooth, fuel mileage is good, so apparently nothing wrong with it.
-After replacing the lambda, the revs went too high on idle so apparently the previous owner messed around with some sort of nut near the throttle body that uses a 3 or 4 hexagonal key and lowered the idle speed (very odd to do that).
-I'm also missing the two tubes/lines that attach to the air filter box. One tube I know that comes from the air intake tubbing, the other one I need to wait for the rain to stop to ckeck from where it comes comparing with my other Cento. Could this be the fault? I mean, people with direct air filters remove them and most cars still run well.
I also checked for master brake cylinder leaks/failure that could induce this problem. Apparently it happens when I downshift and use the brake at the same time. Got the car to idle, pressed the brake pedal a few times and all is smooth, idle wise.
Car is all original... even paper air filter. It has new plugs, oil, filter, etc, etc... I mean, it got a clear MOT 6 days ago.
Car will go to my mechanic next week for a tranquillizing inspection, so I'm just searching for something more specific for him to look at.
Have a great weekend.
Now the issue:
