Technical Coolant bleed screw?
tommol
West Midlands
Anyone know where i can get a replacement? The one that comes from behind the drivers side headlamp Thanks
Think there is a rubber O ring on the plastic screw as well, it leaks otherwise.
If you have a brake pipe/hose clamp that might do as a jury rig.
Noel
[play theme from great escape]
The rubber ring should be in the valve but if you remove the threaded plug, the ring may make a bid for freedom, and when you replace the plug it will leak...
Where shold the ring go then?
Noel
[end theme]
hi ive just broken the top bleed screw, the one thats behined the air box the thred is stuck in but ill be able to get it out, but just ran the fiat garage and they said that they only sell the screw with the hose any idea what the do??? ive seen you all sayin use a 6mm bolt with a washer is that the one near the ras or the one im on about? please please help:mad:
