Thread Tools
Old 15-01-2011   #1
Trader Rating: 1
Speedo wrong?!
Hey,
Over the past few weeks its been pointed out to my that my speedo is wrong.... Most annoying thing is it says im doing 30 and dad folllowed to doing 24! Now I would go say 35 and make it up or whatnot but knowing my luck the one time i do it will be right and i get pulled and i allready have 3 points.... But today was the nail in the coffin when my speedo said i was doing 80 and dad passed me doing 65.... has this happend to anyone else? Also what is best thing to do?
Jamie.
Jamieb is offline Reply With Quote Quote
Old 15-01-2011   #2
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
Re: Speedo wrong?!
most cars over read but you could have a cable from a 899 or a worn one that could be slipping slightly
Ash
if its cheap its generally cheap for a reason
whitz is offline Reply With Quote Quote
Old 15-01-2011   #3
Re: Speedo wrong?!
yeh new cable tbh mate. although my mates did this and it was the clocks at fault... there cheap as chips in a scrappy
clock34 is offline Reply With Quote Quote
Old 15-01-2011   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: Speedo wrong?!
Cable will make no difference, but the head may be faulty.
Have you changed the dial background?
D
Old 15-01-2011   #5
Trader Rating: 1
Re: Speedo wrong?!
Yeah, well I am going to try get new one... It only had new one afew months ago though....
Old 16-01-2011   #6
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
Re: Speedo wrong?!
if the cable looks fine then go back out with a gps or what ever and with the car in 4th or 5th get up to say 60mph and look at the rpm gauge.
go back home... remove the surround and unclip the perspex from the cluster. pull the needle off then jack the front of the car up and put the car in the same gear you used and match the revs then pop the needle back on at what ever speed the gps was showing
not the safest way to do it so use common sense.
way I did mine was... removed the surround and perspex and needle but replaced it on lightly.
drove the car down a well knowen and empty duel carrageway at 60 (satnav speed) then pulled the needle and replaced it at 60.
my speedo reads about 1mph over and about 3mph under at 90mph
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Thread Tools
(T) Seicento speedo wrong hobbsy555 Cinquecento / Seicento 10 11-08-2010 10:30
(T) Wrong strut brace or does my car have wrong suspensin mounts? Momanatorz Punto (Mk2/2b) 7 21-01-2010 20:46
(G) Speedo wrong side Kelvin W Bravo 5 04-03-2008 20:29
(G) I didn't buy the wrong car I just live in the wrong place allanhelen Grande Punto 7 03-06-2007 18:08
(T) Speedo Problem (+Sticky Speedo (1.0 IE)) DannyL Uno 11 29-03-2005 20:19
