SamKeep
Got an issue with a seicento heater, one moment it worked fine then all of a sudden stopped. Ive checked the basics such as fuses and also taken off the heating dash and checked for any loose connections but cannot find any, i have read on here that the heater is also linked with the cig lighter have also checked for any loose connections but again there is nothing visible that i could see... Ive also flushed the radiator system so the heat is coming through.
To confirm it is the blower that has gone and not the heat, for example if i am driving anywhere longer than 10 minutes the heat does come through but there is no force behind it.
Any help on this would be brillant and much appreciated in this weather!
