Bubble1100
- Nov 16, 2010
- 10
- 1
Hi. I am hoping Neil Barnacle or a similar tech wizard can help.
My 1999 seicento is giving Air temp sensor error and Injector driver error when I use the star trek punto as advised and a VAGcom cable with the mod for fiats. I have it connected to a laptop with serial port and the latency set to the lowest possible.
The car will rev when stationary but when I drive it it holds back suddenly when the accelerator is pressed. The management light is on so it may be in get you home mode. I have changed the throttle body for another with temp sensor and injector driver included and star trek punto gave the same errors. Could it be associated wiring or is it possible that I am getting a bad reading for some reason?
