Thottle cable too tight is one cause. Make sure there is plenty slack at idle.
You cannot fit a complete 1108 exhaust, the manifolds come from different sides of the head, but post cat you can use it, although it will need an insert. The 1108 pipe is larger bore than the 899.
D
