cantaffordaferrari
hi all hope someone can shed some light on this for me.
my daughter has a 1999 seicento suite, i.i with air con. it over heated a little recently and the fan wouldn't cut in. i used a paper clip to short the switch on the rad and fan didn't work, so took to auto electrician and he said fan was kaput and switch was faulty , so got another fan (second hand but tested) and a new switch and with the help from peeps on here fitted them, bled the system till a good strong constant flow from bleed and replaced the 30amp fuse.
now if i short the rad sensor switch the fan runs fine but it wont cut in when i run the engine. had thermostat replaced and rad flushed, refilled with coolant and re-bled but still the fan don't work, heater works great, rad heats up evenly and all pipes get hot but the bloody fan wont cut in......what am i missing here? side of rad where switch is gets hot as does all the rad, no smells in expansion chamber and coolant is looking clean and good,so am i an idiot who's missing something obvious, i hope so. any advice would be great. read a few threads but cant seem to find a conclusion.
