A friend of me has a Cinquecento turbo.
1108CC engine with speso headgasket.
Orginal pistons but skimmed down by novitec to lower the compression.
Original fuel pump and injector + extra injector at the back of the inletmanifold for extra fuel.
Original this was a Novitec set with a tectronic.
So the engine ran on the original ECU with an Novitec chip.
And the Tectronic added more fuel if it was needed.
That broke down so we took out the Tectronic and the original ECU.
We replaced it with a KdFI v1.3 (megasquirt based ECU).
As the car is running now for the last couple of months we still think it's slower than the original setup.
Top speed went down to 190km/h instead of 211km/h.
As it is getting enough fuel we think it has something to do with the ignition table.
Would the turbo drivers here be so kind to take a look at the ignition table?
Also I uploaded the config file from tunerstudio.
http://www.mediafire.com/file/ggm4cg8r27oakeb/eerste tuning 500.msq
Maybe you guys can find somthing to gain more power.
