Hi guys
I'm building a high boost SPI turbo with a second piggy back controlled injector and have a question about fuel regulation. Most of the set ups I've read about seem to use a aftermarket regulator for the second injector and retain the original regulator for the primary injector in the throttle body. Surely if you use the standard regulator on the primary injector as the boost increases the fueling will be diminished by the pressure in the plenum and vacum feed for the regulator. This meaning you will have to overcompensate with the second injector? The only way I can see around this issue is by using 1:1 boost increasing regulators independently for both the injectors and disabling the original unit by removing its guts. Apart from the cost of using 2 regulators is there any reason why I shouldn't be considering this? Can the original regulator cope with the added boost with out a boost increasing regulator? I was under the impression N/A regulators rely on manifold vacuum where as turbo regulators rely on boost pressure.
Ben
Ben
