I have tried to help a friend put his 899cc back on the road, all mot’d and legal now but it was running a bit lumpy.
Followed the guide here about resetting the ECU and this seemed to do the trick, next thing as the car had been parked the ongoing problems have started, the alternator was only giving out 11.3 volts, took this off cleaned it and all the earth connections on the car, this is now running at 13.9 volts which means he will not have to call me out to jump start again!
The problem I now have is I put the old fan belt on and as I half expected it failed as soon as it had been tensioned, I would normally have changed this but my friend isn’t working at the moment so trying to keep costs down,
Bought a new one and had fun and games fitting this as I have never done one before, I started by feeling my way back and found the sensor and cable, I disconnected the cable because I thought I would be able to drop the belt over, I then realised I would have to take the wheel off to do this job correctly.
With the wheel off the screws holding the sensor would not move, I rotated the bottom pulley until I had the gap under the sensor, I could then work the belt in. I put it all back together, cleaned the plug for the sensor with electrical contact cleaner and plugged back together.
Now……. The car that was running fine will not start and it shows all of the indications of the timing being out, does disconnecting the timing sensor cause it to forget its settings, or has forcing the belt under the sensor caused a problem by moving it slightly (there is no damage to the sensor) or do I need to reset the ECU, is there a way of checking the crank case/timing sensor? Any advice would be greatly appreciated,
