Technical Removing Seats
exit12
I tried removing the passenger seat tonight from my seicento but to no avail. Trying to make space for when my clutch cable arrives to fit it.#
Shoud it just be a case of removing the 4 bolts with an allen key head? they seem to be stuck fast. I'm taking it it's only these four screws that need taken out?
theres a guide for it on this site for removeing seats havent had to do it my self i did the cable the hard way and got stuck upside down on the drivers seat :)
i can remove all the seats in less then 10mins, tho the back support on the back seat can be fidly to fit some times :p
i take the front seats out just to clean the car thats how easy it is!(y)
I suggest using Copper Grease on the bolts when you refit them, it will stop them seizing up!:D
:) Nice One all,
Will give it a good bash tomorrow.. and won't stop till that bolts turn.
on the black sporting i had the bolts were really hard but i undone them with just an allen-key, i found out after i had them out the a support beam, for the seat 9holding two runners together that the weld had split and moved so it was pushing against the bolts making it rather hard
where as my blue on came out really easy, so it could be just down to much getting in under hte car and sticking to it
Ash
