Thread Tools
Old 26-07-2010   #1
Red Injector warning light comes on.
I have recently purchased a 1999 Fiat Seicento 1.1 Sporting. The car has been perfect for the first three months with no problems at all. A problem has now suddenly occurred. When first starting the car from cold and running it all is well but once I stop and restart a short time later the red injector warning light comes on and the engine runs rough. The crazy part is if I leave the car for an hour or so it starts and runs perfectly until I stop an quickly restart again. Can anybody suggest what the problem is?
Cyprinidae is offline Reply With Quote Quote
Old 26-07-2010   #2
Re: Red Injector warning light comes on.
sounds like a temperature issue check temp sensor
the invader: http://www.fiatforum.com/members-motors-non-fiat/270284-its-ford.html#post2762950
Quote Originally Posted by The Unknown View Post
IV Seen Bigger
Come to the darkside. We have cookies !
dronenrs is offline Reply With Quote Quote
Old 26-07-2010   #3
Quote Originally Posted by dronenrs View Post
Thanks for that dronenrs, do you mean the water or the air temp sensor?
Old 26-07-2010   #4
water temp sensor. by the sounds of it it always thinks its hot so is putting less fuel in but when up to temp itll be fine
IV Seen Bigger
Old 26-07-2010   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
More likely the water sender (in the inlet manifold), but if not check the air temp one too.
D
Old 27-07-2010   #6
Problem is now more serious the car won't start at all (no spark at all 4 plugs). Fitted new plugs, new HT leads and new coil units but still no spark at all! Any ideas?
Old 27-07-2010   #7
i'm gonna go out on a limb and say its starting to sound like a fault with the ECU check the ECU earth if im wrong someone will be along shortly to correct me
IV Seen Bigger
Old 27-07-2010   #8
could be coil wiring if no spark... test the coils
feed the positive with 12v then take it of. it should kick out a spark as you take the feed away. if it sparks you know your coils aint shot check wiring and report back
Rich
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather, -30mm Apex Springs w/ Monroe Reflex Shocks.
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather, Mani-Back Longlife Custom S/S Exhaust.
richydraper is offline Reply With Quote Quote
Old 27-07-2010   #9
Coils are fine.
Old 27-07-2010   #10
the coils themselves may be fine but the wiring to the coils may be faulty
Thanks Cyprinidae thanked for this post
IV Seen Bigger
Old 27-07-2010   #11
What is the best way to check this wiring?
Old 27-07-2010   #12
Quote Originally Posted by richydraper View Post
mentioned about 3 posts up
IV Seen Bigger
Old 27-07-2010   #13
I have removed the low tension plugs from the coil packs and checked the voltage across them with the ignition switched on - nothing. No power is getting to the low tension windings of the coil packs which might be the wiring loom or something more expensive!
Old 27-07-2010   #14
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Crank sensor?
D
Old 28-07-2010   #15
I have cleaned the earth connection to the ECU but still no spark. Can you please tell me where to find the crank sensor?
Thread Tools
(T) injector warning light on steve_fitz1 Punto (Mk2/2b) 4 08-03-2008 00:02
(T) injector warning light on steve_fitz1 Punto (Mk2/2b) 0 02-03-2008 19:16
(T) Injector warning light Hellcat Tipo (Classic) 1 21-05-2006 09:54
(T) Injector Warning Light northernmonkey Cinquecento / Seicento 11 13-04-2006 19:47
(T) Injector Warning Light siytek Punto (Mk1) 5 29-03-2004 16:34
