Thread Tools
Old 31-07-2010   #31
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: Red Injector warning light comes on.
Have you checked the wiring (as suggested earlier by Tinkerbert) to the ignition switch/immobiliser ring? The chip in your key will communicate with the car via the ring and if it has no signal from the ecu, the ecu in turn will assume an illegitimate key. It's not a brand new car so the wiring could be in poor condition or may have just worked loose and been pulled out when you changed the coils over. I believe there is a wiring diagram in the back of the Haynes manual
Thanks Cyprinidae thanked for this post
Eklipze3k is offline Reply With Quote Quote
Old 31-07-2010   #32
Quote Originally Posted by Cyprinidae View Post
They were also too expensive! Is there any way I can start my car without first getting my five digit code? I don't understand why fitting new coil packs, plugs and leads has given me this key code problem as all I had as my original problem was a faulty coil pack! Can anybody help as I am totally puzzled?
Sometimes, when working on electrics and disconnecting the battery the ECU will go out of sync with the chip in the your key. When that happens it is a case of manually re-syncing and unfortunately that means you need that code.
Personally I would find the cheapest Auto-Locksmith and get it from them.
It's a shame you're not a lot closer as we could get it for you. At discounted, forum member rate of course
Tinkerbert is offline Reply With Quote Quote
Old 31-07-2010   #33
No strings on me
Eklipze3k's Avatar
Quote Originally Posted by Tinkerbert View Post
Why does distance matter, don't you just need the VIN and reg number?
Old 31-07-2010   #34
Quote Originally Posted by Eklipze3k View Post
I think, to get the code from a Sei we'd need to plug into the ECU.
I'll find out for you tho.
Won't be til monday tho.
Old 31-07-2010   #35
I have carefully checked the wiring to the ignition switch/immobiliser ring it is fine as is the wiring from both coil packs.
Cyprinidae is offline Reply With Quote Quote
Old 31-07-2010   #36
Sounds like it could be a sync issue then.
I'll find out on Monday if I can get you the code to resync just from VIN and Reg
I've seen things you people wouldn't believe. Attack ships on fire off the shoulder of Orion. I watched C-beams glitter in the darkness at Tannhäuser Gate. All those moments will be lost in time like tears in rain. Time to die.
- Roy Batty Nov 2019
Old 03-08-2010   #37
Tinkerbert,
Have you had a chance yet to see if you can get my code?
Old 03-08-2010   #38
Tinkerbert,
Didn't get a chance yesterday. I'll find out today for ya
Old 04-08-2010   #39
Hey.
I've had a look into getting the code for you and it would work out much cheaper and easier if you got it from Fiat.
Sorry mate.
Old 04-08-2010   #40
Hi Tinkerbert,
Many thanks for your help. It looks like I will have to pay Fiat £35 + Vat to give me 5 numbers. This is my first Fiat and it will definately be my last.
Old 04-08-2010   #41
Trader Rating: 3
ycming has donated!
wait wait ... could you start the car with your key just now ?
ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 04-08-2010   #42
The car will not start. The code key warning light is on continuously and there is no power to the ignition coil packs.
Old 04-08-2010   #43
Trader Rating: 3
ycming has donated!
is it SPI? If it is message gazzaman for a ECU chip, and this will disable the immob code.
and it cost £12 or something
ming
Old 04-08-2010   #44
A silly question but how do I find out if it is a SPI?
Old 04-08-2010   #45
Trader Rating: 3
ycming has donated!
I think 1999 is SPI. To be sure, if you have 1 injector then your car is SPI.
Ming
Thread Tools
(T) injector warning light on steve_fitz1 Punto (Mk2/2b) 4 08-03-2008 00:02
(T) injector warning light on steve_fitz1 Punto (Mk2/2b) 0 02-03-2008 19:16
(T) Injector warning light Hellcat Tipo (Classic) 1 21-05-2006 09:54
(T) Injector Warning Light northernmonkey Cinquecento / Seicento 11 13-04-2006 19:47
(T) Injector Warning Light siytek Punto (Mk1) 5 29-03-2004 16:34
