Thread Tools
Old 28-07-2010   #16
Trader Rating: 3
ycming has donated!
Re: Red Injector warning light comes on.
Undernerth the oil filer, close to the crank pulley.
Ming
Thanks Cyprinidae thanked for this post
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 28-07-2010   #17
Lowered.
SeiSporting's Avatar
SeiSporting has donated!
Immobiliser light go out?
Liam.
1.2 16v Cinquecento HF under construction
Porsche 924 Lux & Porsche 924 N/A
Mini Cooper S
SeiSporting is offline Reply With Quote Quote
Old 28-07-2010   #18
Quote Originally Posted by SeiSporting View Post
I was going to suggest that as well. Could be a problem with the immobiliser ring on the ignition or the wiring to it.
If that's fine, try another key, if you have one. Could be the chip in the key is faulty. If that's the case and you have no spare, I'm afraid it's not going to be cheap to get a new one.
Tinkerbert is offline Reply With Quote Quote
Old 29-07-2010   #19
I have found the crank sensor and have unplugged it. It has a three pin connector it measures 620 ohms from the centre pin to one of the outside pins the other outside pin is open circuit to both the other two pins. Is this OK. The imobiliser light stays on with ignition key in MAR position.
Cyprinidae is offline Reply With Quote Quote
Old 29-07-2010   #20
When you say immobiliser light, which light do you mean? I've just look in my car and can't see a light specifically for it.
Old 29-07-2010   #21
Amber coloured key with CODE written below it.
Old 29-07-2010   #22
Quote Originally Posted by Cyprinidae View Post
Can you believe I have never noticed that light before?
Ok so there could be a couple of reasons for that. Immobiliser ring around the ignition could be faulty/dodgy wire somewhere.
The key could be faulty. Is it the original or a copy?
Old 29-07-2010   #23
Original blue key.
Old 29-07-2010   #24
Is the key in good condition? Sometimes we see original keys that are maffed.
Is it the only key you have? You don't have the Brown/Red one?
Old 29-07-2010   #25
Key is in good condition and is the only one I have. I havent got a code card with the 5 digit number that I need to do an emergency start up procedure so I have contacted my local Fiat dealership.
They want 35.00 + VAT to tell me what my 5 numbers are !!!!!!
Old 29-07-2010   #26
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
UK insurance insisted that these cards were not distributed with the vehicles to prevent easy key cloning. Have you tried a simple reset by disconnecting the battery for a few minutes and reconnecting it? Otherwise a cheaper fix would be to get a mckrich chip or similar to disable the immobiliser.
Eklipze3k is offline Reply With Quote Quote
Old 29-07-2010   #27
Have already disconnected the battery left it for a couple of hours and reconnected it but there was no change.
Old 29-07-2010   #28
You might want to try a local Auto Locksmith, they should be able to get it cheaper than your dealer will.
Old 30-07-2010   #29
I will give that a try.
Old 31-07-2010   #30
They were also too expensive! Is there any way I can start my car without first getting my five digit code? I don't understand why fitting new coil packs, plugs and leads has given me this key code problem as all I had as my original problem was a faulty coil pack! Can anybody help as I am totally puzzled?
Thread Tools
(T) injector warning light on steve_fitz1 Punto (Mk2/2b) 4 08-03-2008 00:02
(T) injector warning light on steve_fitz1 Punto (Mk2/2b) 0 02-03-2008 19:16
(T) Injector warning light Hellcat Tipo (Classic) 1 21-05-2006 09:54
(T) Injector Warning Light northernmonkey Cinquecento / Seicento 11 13-04-2006 19:47
(T) Injector Warning Light siytek Punto (Mk1) 5 29-03-2004 16:34
