I'm trying to figure out the Cinquecento wireing.
This is because I have to connect it to another engine (MPI, punto 75) loom.
As I was studying the diagrams I found out that the plug with the number "100" is the main plug that connects the engine loom to the car loom.
This is diagram number 8.
Also on diagram numer 10.
As I had writen down the colors of the wires on both sides of the mainplug I could figure out most of the wires.
The colors on the engine side of the mainplug and where they go:
Orange/Green -------- Double Relais
Gray/Red ------------ ECU
Red ----------------- ECU
Blue/white ----------- Reverse ligth
Gray/Yellow ---------- Oilpresure sensor
Orange -------------- Double Relais
Black/Purple --------- Dyno
Gray/Green ---------- ECU
Orange/Black -------- ECU
Orange/Blue --------- ???????
Black/White --------- ??????
The colors on the car side of the mainplug and where they go:
Black/Green --------- Fuelpump
Red/White ----------- Instrumentpanel Injector Light
Red ----------------- Instrumentpanel
Blue/White ---------- Reverse light
Gray/Yellow --------- Instrumentpanel warninglight low oilpresure
Green/White --------- Instrumentpanel coolant tempature
Black/Purple --------- Instrumentpanel battery warninglight
Orange -------------- ??? I think this go's to the codebox and from there to the ignition barrel
Gray/Green ----------?????????????
Orange/Black--------- ??? I think this go's to the codebox and from there to the ignition barrel
Now car does'nt have a codebox.
So how to wire do's wires?
I how some people could help me figure out what the last cables are.
I've been searching for the last two week but can't find it on the web.
I'm also wondering what the cable are that are pluged underneath the batterytray. The colors are purple/black and red/black.
I think the red/black on is power for the fuelpump.
But what does the other do?
