Thread Tools
Old 29-04-2010   #1
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
Cinq T-Jet Build
well my college is scrapping a 1.2 brava very soon and it did have a good engine when it came in but the cam belt has been on and off a few times without the locking tool used
im guessing there could be a possible be a bent valve at worst case as the engine hasnt been ran
would be be best to take the spark plugs out and turn it over by hand to check if it hits anything, if thats ok do a compression test to see if timing is out massively?
any help would be appreciated on how to check this, quicker the better as were doing a complete strip down and cataloguing a punto
Ash
EDIT its the 1.2 16v super-fire engine
Thanks centralcentos thanked for this post
Likes centralcentos, blu73 liked this post
if its cheap its generally cheap for a reason
whitz is offline Reply With Quote Quote
Old 29-04-2010   #2
re: slow build 16v cinq
99% not damaged! FIRE are NON-interferance engines... UNLESS its been skimmed past the max mark on the head
Likes MultiRacer liked this post
Rich
'02 Stilo, 1.6, Dynamic, Black, 3 door, Full Leather, -30mm Apex Springs w/ Monroe Reflex Shocks.
'99 Coupe, 2.0 20v VIS, Portofino Blue, 2 door, Full Leather, Mani-Back Longlife Custom S/S Exhaust.
richydraper is offline Reply With Quote Quote
Old 29-04-2010   #3
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
ahh my mistake forgot to mension its the 1.2 16V super-fire
Old 29-04-2010   #4
Trader Rating: 3
ycming has donated!
If the engine, not been running i'd say it be fine! Unless someone tries to turn the pully with a breaker bar :P
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 30-04-2010   #5
Speed Camera Tester
ilsonemo's Avatar
ilsonemo has donated!
only way to tell is to take the head off and take a look inside
Quote Originally Posted by Charnwood Fox View Post
Only if you've got a trump-shuffler standing behind you when you are bent over the engine bay.
ilsonemo is offline Reply With Quote Quote
Old 30-04-2010   #6
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Turn over gently by hand is a good idea, endoscope is an other.
SPD
Old 30-04-2010   #7
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
didn't get a good look at it today as i was busy but timing marks are all lined up
asked how much they wanted it for and they said free as long as i pull it out
Old 06-05-2010   #8
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
well pulling the engine out tomorrow, anything else worth getting of the bravo before it gets scrapped?
taking engine and anything bolted to it (bar gearbox which has had it)
loom
could get ecu, codebox and ignition barrlel but useless as no key
Ash
Old 06-05-2010   #9
arc
this is where i stand
arc has donated!
fuel pump, all the bulbs, fuses, relays, speed cluster (ebay), bits of trim, window motors etc etc
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 06-05-2010   #10
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
Quote Originally Posted by arc View Post
i take them aswell except the trim and motors, id have the whole car but i haven't got room
Old 07-05-2010   #11
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
ok got soem stuff off it today
such as
engine
gearbox (not knackered)
alternator
inlet/exhaust manifolds
engine loom but i belive this is useless to be as its not the same type of ecu or connectors
needs a load of odd nuts and bolts as some are missing but im not complaining as it was free
cinq was taken the the piss out of today when it picked up the engine it stopped after i said it beats walking
will get some pictures up soon
Ash
Old 07-05-2010   #12
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
here are the gearbox and alternator bit grubby but non the less ok
the engine seems alot smaller when its out of the car
some of the damage the one on the is rounded completely so il have to use a star drive to get em out
ECU which is no dowt useless... along with loom
please excuse the crappy camera phone :P
Ash
Old 09-05-2010   #13
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
been going along slowly with this engine, managed to break two star drive's getting the cam assembly off
could anyone recommend a good long reach 1/2" star drive set?
Ash
Old 09-05-2010   #14
arc
arc has donated!
Old 09-05-2010   #15
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
Ahh thank you
seems i didnt look close enough at the bolts
i feel somewhat like an idiot now lol
Ash
Thread Tools
Excessive Carbon build-up - Ulysse 2.0 16v TD Project MaverickJ Tech Talk 0 24-09-2011 21:35
cinq boot build shawzy I.C.E 6 01-02-2008 00:25
(G) 1242 Cinq slow accellerating at 70mph :S SlinkyCinqi Cinquecento / Seicento 46 15-08-2007 16:55
cinq boot build scottc1088 Auction Watch 0 17-05-2006 18:12
Cinq boot build? project-cinqy Auction Watch 4 22-05-2005 15:05
