Technical Cinq T-Jet Build
Telford
well my college is scrapping a 1.2 brava very soon and it did have a good engine when it came in but the cam belt has been on and off a few times without the locking tool used
im guessing there could be a possible be a bent valve at worst case as the engine hasnt been ran
would be be best to take the spark plugs out and turn it over by hand to check if it hits anything, if thats ok do a compression test to see if timing is out massively?
any help would be appreciated on how to check this, quicker the better as were doing a complete strip down and cataloguing a punto :yum:
Ash(y)
EDIT its the 1.2 16v super-fire engine
re: slow build 16v cinq
didn't get a good look at it today as i was busy but timing marks are all lined up
asked how much they wanted it for and they said free as long as i pull it out:slayer:
well pulling the engine out tomorrow, anything else worth getting of the bravo before it gets scrapped?
taking engine and anything bolted to it (bar gearbox which has had it)
loom
could get ecu, codebox and ignition barrlel but useless as no key
Ash(y)
ok got soem stuff off it today
such as
engine
gearbox (not knackered)
alternator
inlet/exhaust manifolds
engine loom but i belive this is useless to be as its not the same type of ecu or connectors :bang:
needs a load of odd nuts and bolts as some are missing but im not complaining as it was free :D
cinq was taken the the **** out of today when it picked up the engine :( it stopped after i said it beats walking(y)
will get some pictures up soon
Ash
here are the gearbox and alternator bit grubby but non the less ok
the engine seems alot smaller when its out of the car
some of the damage :( the one on the is rounded completely so il have to use a star drive to get em out
ECU which is no dowt useless... along with loom
please excuse the crappy camera phone :p
Ash
been going along slowly with this engine, managed to break two star drive's getting the cam assembly off :bang:
could anyone recommend a good long reach 1/2" star drive set?
Ash
If you get the code reader, pickup ring and a key then you can use the ecu for the engine. Also cut off the ecu connector from the other part of the harness.
more wiring yayyyy;)
not the most keen on wiring but im guessing it would be easier to use the punto loom and ecu and make up a connector (like gergor) to connect the two together, as i wouldnt want to mess up the car loom
Ash
got a set of ribe from my local dagar tools for dead on £20 so nice
got the head off today, gasket ended up stuck to both sides (n) but bores
were spot on:) all i need to do now is de-coke (carb cleaner?) the head mild port n polish and skim
im unsure on the flywheels here, as far as i know the 1.2 has a 190mm clutch, is this measured by the overall circumference of where the fiction plate touches the flywheel ?
Ash
Friction plate.
Port and polish is recomended by me :D.
Fiat heads I wouldn't say are badly casted but are very restricted in my opinion. Removal of the cast marks and opening the chambers up a little will improve flow nicely.
Also Do a port match exhaust side using a genuine fiat gasket (y).
