Technical Cinq T-Jet Build
re: slow build 16v cinq
bad pic but you can see it just under the arch. backs tucked too :) (thats y i said i cant see hwo u can run a lower arb mine was almost un-movable lol. my arb is also batttttered :p)
and the sump is...
can see the arb dropping in background.
so can we play who can go lower? :p
looks really nice but not the best for in Britain with all these speed bumps and pot holes
i would kick myself ive i was ever to buckle or kerb one of those alloys
a 70/50 kit on 14" wheels should have enough clearance to keep me happy
Ash
yeh hijack lol. his looks a tad lower. yeh his wheels are definatly not as far in as mine at the front (defo are at the back low as f***:p) sure there 14"?
will be able to test fit the engine soon only a few niggle things hindering me
1st small and easy thing to do was gearbox had two locators for one hole so pulled one out and that's done
bolt in gearbox snapped for n/s mount does not want to come out, worst case change the case
see the problem there ?
ive got that selector on the wrong way so when its the correct way clutch piston is in the way so will have to make up a higher bracket to clear
missing a plate here to take the sporting mount as the 899 is different
how it was tonight ready to be moved out of the garage to go under the car
flywheel is off with brooky
also car filled up with water under the floor pan:eek:
Ash
there are loads of different mounds you can use. front mount from a cinq, side from a sei. and bannana style side from a sei sporting V reg onwards.
got the plate from the scrappy today for free :slayer:
did notice the sei sporting has M10 bolts for this to the chassis where the s Cinq has M8, so that's useful to note
started to rain as soon as the engine came out of the garage :mad:
plenty of clearance to the strut brace
clutch cylinder held in place, should be enough clearance here
didn't realise how far forward the engine sits either, very minor job to sort
Ash
Looking good, especially all the new shiny bolts. :p Is that the custom brace? Any problems shutting bonnet?
Looks like the sparco brace.
Everything is starting to come together now (y).
Doing your brakelines next?
X
not sure which one it is but i got it off mariocinq and he modified it to fit around the P75
got all the brake lines done (need putting on car) also just need to pick up front brakes from somewhere, along with rebuilding the rears
Ash
tiny update
flywheel is down to 4.65KG :slayer: im happy with that Thanks Tom(y)
got a new Master cylinder as i didn't store the old one correctly and now not happy with how it feels
also got a re-con starter as it was going
all of the internal sound proofing of the floor is out just need to clean half of it up with white spirits, used and angle grinder with wire brush to get some bits off, big mistake made one hell of a mess :S
engine coolant hoses, 240 vented set-up on the front from Steven soon to be on its way(y)
decided as im getting less time to work on the car im going to try and get the engine running in around 2 months as a milestone to motivate me in this weather
so to get the engine going i need to;
.re-do all fuel lines
.source punto sporting ECU and bits to run the engine
.install and repair sporting loom
.put on fuel tank and pump
.fit flywheel and clucth
.put some temp exhaust together just to fire it up
sure im missing something
need to get a full set of 14" steel's never would of thought id find them hard to get my hands on so i can take the car off stands and have the brakes
lets see if i can do it in time :eek:
Ash
got some more bits done but weather is slowing body work down
.SS manifold came up on ebay so snapped that up
.going to run full flexi fuel pipes - on its way
.one of the rear callipers put back together - easier then i expected but fiddly
.fuel pump should be on its way down to me soon
.flywheel arrived :) gave it a clean and degreased
Ash
with this its just 1 step forwards and 2 steps back so going ot have a long break from this for a while
on my 3rd gearbox, recon starter i bought for a 1.1 is for a 899, fuel pump was thrown away
Ash
