U Unoturbo'd Patron member Joined Sep 2, 2006 Messages 50 Points 14 Location manchester Mar 20, 2010 #1 hi, i'm changing the engine in my sei for a 1.2 16v can i use a punto, will the existing drive shafts fit and gear selectors cheers
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Mar 20, 2010 #2 Punto box is the same physically, as a cento box, although the ratios are different. The clutch operation of a Punto is hydraulic, the cento, cable. So change over the clutch arm to a cento arm to work with the clutch cable. Cheers SPD
