| Principality Retained :) | Brake Pad Compounds Right confusing one here... Im gonna run uprated pads on standard discs, yes, I know it seems like half an effort, but I cant warrant spending 3x as much on discs, when I cant really forsee such a small car really needing them....plus Im not driving it that hard atm (cos the 1242's real noisy!!) So, to get to the point, im looking for recommendations for brake pads....particularly if anyone had any experience of Mintex 1144? They seem to cost 2x as much as their competitors, but seem to give the biggest differenmce over OEM in stopping distance.
| hi friends :waves: | Re: Brake Pad Compounds I have always thought the harder compund pads can ruin the standard discs but some folks on here run that so can't be the case. Liam
__________________ CINQ SPORTING WING MIRROR IN BLACK FOR SALE O/S 97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND | ||
| | #3 | ||
| Principality Retained :) | Re: Brake Pad Compounds Well..Id think that a higher Coeff. of Friction would def mean that the disc would get hotter, so poss liable to warpage, but thats the only major prob i can foresee
| | #4 | ||
| mad bad and very very old | Re: Brake Pad Compounds 1144 is a reasonable compromise in terms of cold and hot response. It is a proper competition compound so its not great when very cold, but the performance stays reasonably constant through a large heat range. If you do a lot of stop start town driving don't go for a competition compound. They are also quite noisy. There is no point in putting a higher performance pad in if you haven't changed your fluid recently. All you will do is put more heat into the caliper and that will boil any water in the fluid. You might also want to consider new flexi hoses. They don't need to be fancy reinforced ones, but the rubber does age badly. When you press hard on the pedal the hoses can expand if old and soft leading to a spongy pedal. cheers D
__________________ If it has pistons or tits, its going to be expensive. | ||
| | #5 | ||
| Re: Brake Pad Compounds On that note. I have replaced the hoses at the front of mine with Goodridge stainless. I didn't do the back cos it is a biatch to get to. Theres a fuel tank and trialing arm in the way. Does this now mean that most of my braking effectivness go on expanding the rear hoses?
__________________ | |||
| | #6 | |||
Cheers D
__________________ If it has pistons or tits, its going to be expensive. | |||
| | #7 | ||
| Fat pigeon... APPLE! | Re: Brake Pad Compounds I've been very impressed with my EBC Greenstuff pads, they bite hard from cold and I can't get them to fade even on a thrash down the Snake Pass
__________________ Back in the day: mildly-modded Punto 55SX; rusty Ford Capri 2.0 Laser Then: mk2 Focus Zetec Ti-VCT; same Capri, less rust ![]() Now: Bravo Dynamic 150 MJet, in red, with extra toys same Capri, same rust ![]() | ||
| | #8 | ||
| Re: Brake Pad Compounds Apec pads are pretty cheap but very good. On the subject of Mintex, you definately pay for what you get if you are plannig harsh road or track use.
__________________ Gaz | |||
| | apinnard | Marea | 1 | 10-12-2004 08:50 |
| | cruisestoke | Cinquecento / Seicento | 2 | 01-10-2004 13:31 |
| | cscotson | Bravo / Brava | 0 | 14-09-2004 11:25 |
| | andy279 | Cinquecento / Seicento | 1 | 05-05-2004 16:06 |
