You didn't disturb the reverse detent cable, did you?
SPD
On the front of the selector tower.
SPD
Yup, just behind the clutch arm
SPD
I dont think i did but i may have would that cause the problems i have atm?
Could do.
What exactly is happening when you try to put it in reverse?
SPD
So the lever isn't going far enough over. Make sure the inner cable brackets are in the right place.
SPD
It feels like it goes over far enough but when it feels in it drives forward
The lever in the car is going far enough, the gearbox end isn't, you are in fourth.
SPD
This does indeed sounds like exactly my problem!!!!!!!
Keep us updated on how u fix it
Ming
SPD
So there is actually nothing wrong ?
Ming
