General Fumes
General Fumes
mustard
nice and hot!
saff east london
i wonder if anyone has experiance this or have an idea what this could be, when i had my 1108 engine in my cinq i had no problems at all with fumes but since i have changed the engine there is a smell , it a weird smell like a mixture of petrol and exhaust fumes. i have also been having headaches which i believe is due to this. i have looked at the exhaust and see no signs of nreaks or cracks the only thing is that the cat is badly dented. i can only think it maybe the breather pipe i have had a quick check but cannot see any cracks or split in it. so i am lost to were this smell is coming from? any ideas?
Mustard
Fresh air enters the habaticle through a vent at the bottom of the windscreen.
There should be a rubber seal along the top of the bulkhead that seals the bonnet from the heater box.
If that rubber seal is missing or compromised, fumes will get from the engine bay, through the heater box, into the car.
SPD
cheers for that, i have the rubber seal running across the bulkhead, however i did take off the sound proofing that covered the heater fan and goes behind the battery. would that make a difference?
thanks
Mustard
no i never touched the wiper motor, will put the soundproofing back on to see if it will make any difference.
Thanks for your help
Mustard
Mustard
hi mustard
since i put my 1242 in i have had exactly the same problems but i have changed wiper linkage so wondering if i have not put mine back together quite right and like u i have the rubber seal across the bulkhead.i suffer with migraines and always get one after half hour in the car without windows open.....getting bloody annoying!!!!!
hi mustard
Hello mate
The last thing i'll do is find out exactly whats wrong, i know what you mean about it being annoying as i never suffer with head aches and now i get it everyday but i will do what levemir said and look at the fuel tank. have you taken the soundproofing that goes across the bulkhead and covers the heater fan?
