soozukisteve
Having already done the punto 75/cinq hybrid and a full 75 engine conversion I have decided to give a 1.4 8valve grande punto conversion a go!
I now have a full 1.4 8v and various other bits and pieces including a punto 75 head and cam.
Initially I was planning to use the 75 head and cam(modded) on the 1.4 block but am awaiting some posts in the punto section regarding the valve sizes on the gp.If they are bigger (and the manifolds fit without (much) modification, i will leave the gp head on and just do a bit of port matching.
I am also hoping that i can get away with using the 75 cam and not have any clearance issues as the gp has a higher comp ratio (11:1).
I will be using the standard sei (mpi) inlet manifold but will be using a bigger throttle body and at some point later,I will source a four branch exhaust manifold and fit a small cat further down the exhaust.
An issue did crop up while checking the auto data though.It tells me that the sei mpi fuel pressure is 1.2 bar (thought that was the spi?).I anticipate needing the 2.5bar I thought it ran at(will test it over the weekend though).
I like to keep things super simple so will only play around with the efi system if totally necesary.I plan to get it running in the car and check the injector duty cycle on a run to see if I need to increase the fuel pressure any which I hope will be enough to fuel it properly.I will consider slightly larger injectors if I really have to but dont intend messing with the ecu at all.
I dont know if anyone has attemted this conversion yet but I would love to see about 90bhp (I have seen standard gp bhp figures between 77 and 84) for the time being but am looking into forced induction in maybe a year or so when funds allow.
What does everyone think?....
