Top up and bleed the system (bleed screw is by the window washer reservoir, sometimes there's an additional one on the engine bulkhead where the heater hose goes through the carpet).
Check for integrity/existence/tightness of alternator/water pump belt, water leaks, check that the cooling fan comes on, check that the thermostat works (radiator gets hot).
