hello guys been a while since ive been on, the cinq is still alive and sort of well,,,,,in its own way, since the last time i left a post id just had the cinq on the rollers at a bar of boost after lowering the c/r using 2 head gaskets and a decomp plate! after finding out my head was heavily skimmed, and on the rollers i came across the problem that at a full bar of boost the car was only making 118bhp and 126lb/sf of torque. this was down to a few things but mainly beacuse the inlet temps where so high (62degrees) due to the turbo having to work to hard and thus heating up the air and cancelling the power out, the problem was less apparent at 0.8bar but the big drop in c/r meant power was down to 112bhp and the same torque (116bhp/116lb/sf on the higher c/r at 0.6bar previous)
since then i re-routed my intercooler piping up above the gearbox and spun my bob round 90degrees, fitted an intercooler spray and had a full new 2" decat exhaust with better bends, i also fitted a 1.4 stilo clutch, back at the rolling road it made 125bhp and 135lb/sf @ 3750rpm. however it seems that the turbo really is out of puff, and i am moving onto a new engine spec (16v rods and pistons, knock controller, big f/m cooler) so i need to flow more air!!!
the turbo is an ex low boost garrett t15/gt15!? fitted to what i believe was a golf/audi tdi 90bhp, thing is id like to switch to a t2 but i no it will cause alot of probs like moving the rad,oil filter,having the comp housing moved to fit, exhaust etc so im looking into hybriding my turbo or finding a high boost t15 which seem to make a fair bit more than mine for the given pressure.
ive had no luck getting info on the t15 so see if any one can answer these questions
has anyone exsprienced the max limit of the low boost t15s turbine housing??
has anyone hybrided the low boost t15??
and although it will have been said a million times what car exactly did the high boost t15/gt15 come off, i no its vauxhall but, engine,year,modle etc
by the way the car is going really well, accelerates like a cheater! reached a sat nav reading off 124mph recently and itll stay firmly attached to the back bumper of my mates renault megane r26 237bhp 2l turbo upto 80 and he stands no chance of pulling away between roundabouts and trafic lights
i can just tell its lacking when the revs get very high when optimal flow through the tub is needed
and something intersting for you, by moving my bob the injector sits on the left facing directly down the side of the standard injector and my fuel distribution probs have gone, all for plugs come out the same colour!!
thanks
jason
thanks
jason
