Thread Tools
Old 14-09-2009   #1
Guadeloupe
idle valve control problem
Hi, I will buy a new idle valve control (idle sometimes at 2000 or 1500 rpm then works fine at 900-1000 rpm).
My engine is the 1242 8v mpi 75 but it runs with 40mm tricker tb.
I just want to know what idle valve control to buy:
Part number: C95136
Applications:
FIAT Cinquecento 1.1 Sporting 176B2.000 10.94-07.98 40 54
FIAT Panda 1000 i.e.
FIAT Punto (176) 55 1.1 176A6.000, 176B2.000 09.93-09.99 40 54
FIAT Punto (176) 60 1.2
FIAT Seicento (187) - 1.1 176B2.000, 187A1.000 01.98- 40 54
Or Part number: C95196
Applications:
FIAT PUNTO 4-1242cc 1.2L 1.2i 75 SOHC 8v Hatchback, 75bhp Eng 176A8.000
Are there differences between these two parts?
fiat punto mk1 1L2 8V 75 mpi:dia bmc, 43mm tb, ported p75 inlet manifold, 280 c&b cam, ported gasflowed and skimmed(10/10) 75 head, supersprint manifold, full supersprint exhaust system, decat pipe, 3 bar fuel reg, trofeo mpi chip (7600rpm), kv85 magnecor, vernier pulley, lightened flywheel, spesso racing hg.
timeless is offline Reply With Quote Quote
Old 14-09-2009   #2
Trader Rating: 5
fingers99 has donated!
Re: idle valve control problem
Check for air leaks/map issues/throttle slack and binding nipple first. As for the right part, really don't know -- I doubt if there's any significant difference except the Punto 75 one. (Which is the wrong one.)
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 14-09-2009   #3
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
75 one is the same to. not sure why the have different numbers :S
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 14-09-2009   #4
Guadeloupe
Ok thanks
Thread Tools
(T) Idle control valve ozfish Ulysse 3 07-08-2009 00:17
(T) sticky idle HELP PLEASE! Idle control valve? j555boy Punto (Mk2/2b) 7 25-05-2009 21:25
(G) Idle Control Valve - where can I get one? butterflylady131 Punto (Mk2/2b) 0 17-02-2009 19:42
(T) idle control valve Diamond21 Punto (Mk2/2b) 1 19-09-2006 14:50
(T) Idle Control Valve Chipper Cinquecento / Seicento 4 17-12-2004 10:42
