smartornot
- Sep 11, 2009
- 9
- 1
Hi All
I have a problem with the cooling fan not switching on. The fan works fine if I remove the wires from the green thermo. switch on the rad. and join the wires. I bought a new thermo. switch and this did not work. The Fiat dealer got me another but still does not work. I believe the switch should just create an earth across the contacts when hot so tried putting in it boiling water but this did not create an earth but not sure if this is a valid test?
Can anyone suggest what the problem can be. The fuse and fan are fine as they work if I bypass the thermo switch on the radiator.
