The radiator fan doesn't come on even when the header tank is overflowing with boiling water. I've checked all the pipes including those to the heater (which blows hot) and all are hot so I think that rules out the thermostat. I've replaced the 30 amp fuse behind the battery so I now get a voltage reading on one of the contacts in the plug that goes into the switch(green) on the radiator. Should I get a reading in both? I also did the paperclip test across the plug contacts which glowed red. I've swapped a relay from the fuse box with the one on the ecu and checked the 7.5 amp fuse for that. The only other thing I can think of is the fan motor might be broken. I've read that you can test this by use of a side contact? Where is it? A picture would be good. Any other suggestions?
Cheers.
Seicento 899cc T reg.
Cheers.
