Hi all, currently trying to start the car, and we have a wiring problem which i think could be possibly be down to the fiat 'code' system....
Hopefully someone on here may know what the fault is.
Simply between the battery terminal connections (without the battery being in place) we get no contact between the two terminals.
Upon putting the key in the ignition and turning the key to the 1st click, we are getting a connection between the power and earth terminals.
On every positive point on the car we have checked, it faults to earth.
Visual inspection on all wires, and everything seems to be correctly wired.. (its been removed and refitted 3 times)...
We think that the code system may be preventing the wiring to work correctly, and not sure how to get around it, as we dont have the fiat ECU connected... so im thinking that if it was connected, the key would activate the wiring by some sort of switch, and not throw up a connection between 12+ and earth.
Can anyone advise?
Can anyone advise?
