tnt
The problem is as follows: the fuel tank on my 99 Seicento Sporting was replaced because was rusted and leaking. New tank fitted. I made a full refill and the problem appeared. Even if the tank is full, the fuel gauge on the dash will only point ~ 1/2 of the level (like I had only half of the tank filled with fuel). And will stay in that position until half of the tank will be used (~ 300 km), an after that, it starts to move counter-clockwise (as normal) and indicates the correct level. I repeated a few times the full refill and this was the behaviour... it is like something is not letting the gauge to move further the 1/2 level on the dash. But the problem is not on the dash side.... is somewhere in the tank. In the fuel pump i suppose. Does anybody have any clues how can I fix'it?
