Jules Sei
- May 20, 2009
- 48
- 10
Please help.
Needed to change the water pump because it was leaking.
Thought it would be a good idea as a new owner to chance the plugs and leads, and timing belt and tensioner as well.
Need a couple of questions from knowlegeable member answered.
If I say plug one is on the left of the engine as I stand in front of it, and there are four coil points running towards me, from the bulk head to the the raidiator as I look at them, let's say 1 is closest to the bulk head and 4 is nearest me. Based on this, which plug goes to which coil ?
Under the airbox there are two vacuum hoses, one comes from the throttle side and one comes from the intake side. If the airbox is mounted on the throttle which one goes to the left connect and which one goes to the right, looking onto the airbox from above.
I have changed the water pump and thankfully no leaks, the belt the factor gave me is the wrong one, I have reused the old belt.
The car starts and will rev fine, but will not idle, I'm stuffed, please help.
Cheers, Jules
Cheers, Jules
