Technical coil packs
Bobby Punto
Barnsley
Hi folks
Yes I know I am in here I now have cinquecento as I swaped my punto for it.
few problems, but main one at the moment can someone tell me which plug lead goes to whick coil pack port. Thanks loads :worship:more ??? to come sone :bang:
Sorry guys did not mention 899 engine and 1995 cinquecento,
thanks arc thats the sort of thing I was looking for. but my coil packs are vertical, or are my packs wrong.
Thanks lads but was hoping someone would spend 2 mins just to nip outside and look, but, rallycinq you said the photo fron arc is same as, but which is at bottom number 4 or number 2.
they are actually numbered if you look closely at the casting, also, the coil packs are not symetrical, so you should be able to tell which way they are rotated on the 899cc, i would go look at mine.. buutt it has a stilo engine in there.. so, erm, not helpful lol
The short answer is that leads 1 and 4 go to one coil, 2 and 3 to the other.
If you have flames in the TB you've got them wrong, so change them in pairs.
I too would look under the bonnet, but would only find a 2.5 litre turbo diesel.
SPD
ps I'm driving my Land Rover at the moment.
Thanksa again you 2 will try adviced and if I don't blow up I know it's right, also I did look under bonnet but closed it again fast as only standard 899cc and not upto your grade by looks of things lol lol :):worship::bang::bang::bang:(y)
sorry for this message but arc, just noticed where your from pooor boy! someone needs to keep place open:);):yum::worship::worship: lol lol, I used to be in blackpool
ok lads won't mension that again, thanks again for advice and will have a look at car tomorrow. And credit were it's due, you both have adviced and helped many people on forum and you both have my respect for that, hope I can be as helpful to others on here one day.:worship::worship::worship::worship::worship:
