The FIAT Forum
Old 17-10-2004   #1
Trader Rating: (0)
Exclamation brakes help asap
i got a huge problem need help need car for tomorrow some things gone down i now have no front brakes just rear any ideas gett back asap thanks chris
Chris
collossus1st is offline
Old 17-10-2004   #2
mad bad and very very old
rallycinq's Avatar
Trader Rating: (1)
Re: brakes help asap
The brakes are split diagonally, so you can't have lost just the fronts, in theory. What state are the pads in?, are the calipers moving OK?
Get back to me
D
rallycinq is offline
Old 17-10-2004   #3
Trader Rating: (0)
well at first i thought it was the pads but i change them but still no joy also blead the brakes could it be the brake servo thats my last idea please get back
Chris
Old 17-10-2004   #4
rallycinq's Avatar
Trader Rating: (1)
Did you check the calipers are moving OK. If you have fitted new pads and the caliper is stuck then that would cause a problem.
Is the pedal hard, or does it go to the floor?
D
Old 20-10-2004   #5
mic.neale's Avatar
Trader Rating: (0)
your problems sound simular to mine, little or no front brakes and having to pump to stop hard
i replaced the servo and M/C with 1 from a scrappy, replacing the servo and M/C is a right pain, the gearbox is in the way, but lots of kicking a screaming gets it in... i'm hoping for you that it isnt that.
Fix the fiat so its at ok'ish working condition,
Sell it off to some1,
Then by another fiat with twice as many problems as the first 1.
Its the fiat life for me.
mic.neale is offline
Brakes failure Dean062 Multipla 10 10-08-2006 12:26
(T) brakes Diesel20 Stilo 11 11-05-2004 19:06
(T) Disc brakes on punto from Tipo or Bravo HGT Davey1 Punto 6 09-04-2004 16:10
(G) AHHH my brakes dont work! Bushboy Uno 6 13-11-2003 23:58
(T) Brakes, brakes, brakes my cinq now Cinquecento / Seicento 10 17-10-2003 19:33
