| | #16 | ||
Posts: 518 Thanks: 3 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT
__________________ ![]() Now with Garrett GT1752 hybrid turbo - going for 150bhp low boost and high boost???? who nows! bring on the rolling road | ||
| | #17 | ||
| | Re: SERIOUS cutout at 2-3k-URGENT I found that the original vac hose to map was constantly splitting, along its seam, I swapped it for another piece of similar hose and that did the same after a while. What I am using now is some black washer pipe hose from a ford escort, it has soem sort of braiding in it and is more plasticy than rubbery, no problems with it at all.
__________________ | ||
| | #18 | |||
jason
__________________ ![]() Now with Garrett GT1752 hybrid turbo - going for 150bhp low boost and high boost???? who nows! bring on the rolling road | |||
| | #19 | ||
Posts: 560 Thanks: 2 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT still that problem, its not always, sometimes its fine sometimes not-when around 2-3k, its loosing revs/power-need to press clutch, press gas, rev and its fine again, looks no matter of temp it was allright before new clutch, cvjoints, radiator, etc.. I hope its only some bad conenction, or could be a resetted ecu issue??? (battery out for few days) because no changes to engine(except leads and plugs-is 0.9mm gap right???) maybe its still that vac hose(maybe hose isnt too stiff and its changing its diemater) but why only at low revs, and at high its running great..??? I have parts from 899cinq- is lambda, and map sensor, and other sensors the same. ???? could swap them for a try thanks
__________________ Revival in progress - Grey Cinq 1.1 Sporting'96, Silver 13" alloys, Black 165/55 NANKANG tyres, Red seatbelts, Sony >Xplod< 880W I.C.E, ColdAirIntake with Sprintfilter, De-cat with backbox edit. Named Theresa - Topic HERE Last edited by Diwiak; 26-02-2009 at 19:46. | ||
| | #20 | ||
Posts: 560 Thanks: 2 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT problem still here ![]() and worse, its not responding to throttle wheen keeping constant revs(between 1.5-3k), need to release gas pedal, then push it and its reving again-injection control light is still off
__________________ Revival in progress - Grey Cinq 1.1 Sporting'96, Silver 13" alloys, Black 165/55 NANKANG tyres, Red seatbelts, Sony >Xplod< 880W I.C.E, ColdAirIntake with Sprintfilter, De-cat with backbox edit. Named Theresa - Topic HERE | ||
| | #21 | ||
Posts: 495 Thanks: 9 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT Here's something you could try for free: swap the two lambdas, it's a 30 minute job at most, see if that helps.
| | #22 | ||
| | #23 | ||
Posts: 495 Thanks: 9 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT Some people reccomend heating it first, some say to use a lambda socket, i managed it without (iirc, it was a 22mm spanner). Best do a search first.
| | #24 | ||
Posts: 560 Thanks: 2 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT will some cleaning of it helps??? and i forgot, right after finishing job i clean whole car, engine aswell-where could water get into???
__________________ Revival in progress - Grey Cinq 1.1 Sporting'96, Silver 13" alloys, Black 165/55 NANKANG tyres, Red seatbelts, Sony >Xplod< 880W I.C.E, ColdAirIntake with Sprintfilter, De-cat with backbox edit. Named Theresa - Topic HERE Last edited by Diwiak; 28-02-2009 at 14:05. | ||
| | #25 | ||
Posts: 560 Thanks: 2 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT thanks for help, it was finally(as you said) lambda sensor-i didnt notice before that cutouts are not when cold, swap lambda with 899's from scrap(its same, 899s have longer lead)-running allright, idle is much better btw. swapped more things from 899 engine, throttle pos. sensor is the same, map sensor too, vac hose is longer but same, idle control valve is different worse thing is smoking, sometimes a lot sometimes not, its white/grey smoke, couldnt notice coolant loss yet (200miles done), theres few drops from exhaust, smells not like coolant, also fan is starting at 95degreees(which i think is high), temp going almost to 100 degrees while not moving, but will not boil-could be H/G leaving me or waterpump(didnt change it together with timing belt)??? 70k mileage.
__________________ Revival in progress - Grey Cinq 1.1 Sporting'96, Silver 13" alloys, Black 165/55 NANKANG tyres, Red seatbelts, Sony >Xplod< 880W I.C.E, ColdAirIntake with Sprintfilter, De-cat with backbox edit. Named Theresa - Topic HERE Last edited by Diwiak; 02-03-2009 at 19:51. | ||
| | #26 | ||
Posts: 15,610 Blog Entries: 3 Thanks: 662 Trader Rating: 1 | Re: SERIOUS cutout at 2-3k-URGENT Could just be the cat getting cleaned now the engine is running properly. If you are not losing any water, do not panic. Cheers SPD
__________________ Marriage sounds like a grand idea. Divorce is more like a hundred grand | ||
| | #27 | ||
Posts: 560 Thanks: 2 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT Lambdas keep dying??? cinq starts to make me f***ing mad.. ![]() swapped lambda, start engine, done 80miles, running allright, keeping at 85-95 degrees, cruising at 1500-2500, no problems at all, city, regional road, accelerating nice, idle nice(yupi). today checking coolant, at max, running through city, 85-90temp, no problems,10 miles done. afternoon, start engine, warm up till 85-90 - again serious cutout at 2000 when moving(not accelerating, while keeping the same revs) from lights, then several cutouts through city. stop engine, disconnect lambda(injection light normally turnedoff after secs and didnt come out when running), engine runs bit rough but no cutouts. stop engine (still warm), connect lambda, cruising 1500-2500, running fine, stoped car, running idle, engine went to 110 degrees, no boiling, just pressure, moved with car, cruising, temp went down to 85, again serious cutouts.... WHAT THE HELL IS WRONG WITH IT??? next lambda sensor gone???????? no mayo on both caps. coolant, oil looks normal. just white smoke - sometimes. and pressure in expansion tank. ANYONE have an idea??? why isnt injection light showing disconnected lambda??? should be HG gone??? couldnt be some wrong petrol???? really appreciate your help...
__________________ Revival in progress - Grey Cinq 1.1 Sporting'96, Silver 13" alloys, Black 165/55 NANKANG tyres, Red seatbelts, Sony >Xplod< 880W I.C.E, ColdAirIntake with Sprintfilter, De-cat with backbox edit. Named Theresa - Topic HERE Last edited by Diwiak; 03-03-2009 at 20:30. | ||
| | #28 | ||
| | #29 | ||
Posts: 518 Thanks: 3 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT my lambda sensor caused the same faults, thats why i suggested it early on in the thread, shame there so exspensive new, after i fitted a new one in mine it was pretty much perfect, slowly going back to how it used to be now ![]() jason
| | #30 | ||
Posts: 560 Thanks: 2 Trader Rating: 0 | Re: SERIOUS cutout at 2-3k-URGENT but new(used) lambda was fine for 100 miles nad now its gone again..???? dont want to buy new one and see it will go too really thinking of ordering new hg, lambda, waterpump tommorow, remove it and see whats wrong - cracked head 2 pistons gone ![]() and hole in block ![]() i could have new cinq for such money..
| | Panda1rimshot | Punto | 15 | 21-06-2007 10:20 |
| | AshG | Cinquecento / Seicento | 7 | 09-06-2007 13:39 |
| | 5doorturbo | Uno | 1 | 18-05-2007 09:03 |
| | adaze | Punto | 5 | 25-11-2006 16:24 |
| | ConfusedScot | Bravo / Brava | 1 | 22-02-2006 09:44 |
