Technical FOG Lights
GunsNRosesLover
Norwich
Does anyone know the size of the screws used to fit Fog lights to a seicento sporting as i have the lights but donot have the screws to fit them.
They are long bolts with phillips (screw driver) style heads, think the nuts are normal hex but they might be square.
I'll measure mine tomorrow, but any screw long enough and thin enough will do, you will need to heavily grease or screwtight the nut and screw at the inside end cause without it wont undo after a winter of salt, even if the screw is plated.
Noel
Hi
The screws are 49mm long in total, cruiciform screw head.
The shoulder i.e. locating section is 19mm long 5mm diameter, the thread is 27mm long including pilot the thread is 4.8mm diameter.
The nut is square (i.e. not hex) 7.8mm across the flats. it is coded 'L' & '5' diametrically
They are anti corrosion plated. They wont undo if they have been fitted a few years...
Noel
