"emergency Start Up Procedure"
1.read The 5-figure Electronic Code Given On The 'code Card'.
2.turn The Ignition Key To 'mar'
3.press The Accelerator Pedal To The Floor And Keep It There.the Injection Warning Lamp Will Light Up For About 8 Seconds And Then Go Out. At This Point Release The Accelerator Pedal And Get Ready To Count The Flashes Of Warning Lamp
4.count The Number Of Flashes That Code On The 'code' Card,then Press The Accelerator Pedal And Keep It There Till The Injection Warning Light Comes On For Four Seconds And Then Goes Out; Release The Accelerator Pedal
5.the Injection Warning Light Will Start To Flash Again:after It Has Flashed The Number Of Times That Corresponds To The Second Figure On The 'code' Card,press The Accelerator Pedal To The Floor And Keep It Ther
6.do The Same For The Remaining Digits On The 'code' Card
7.once The Final Digit Has Been Entered, Keep The Accelerator Pedal Pressed.the Injection Warning Light Will Light Up For Four Seconds And Then Go Out.release The Accelerator Pedal
8.the Injection Warning Light Will Flash Rapidly For About 4 Seconds To Indicate That The Operation Has Been Completed Correctly
9.start The Engine By Turning The Ignition Key From 'mar' To 'avv'
-if The Injection Warning Light Remains Lit,turn The Ignition Key To 'stop' And Repeat The Procedure From Step 1.
-important-after An Emergency Start, You Should Contact The Fiat Dealer,otherwise You Will Have To Repeat The Whole Procedure Each Time You Want To Start The Engine
Emmx
Emmx
