Hey peeps,
Am sure the regular FF - Cinq/sei section are definitely starting to see a common pattern with faults that comes with our beloved little cars. I guess, I'll make this thread and name several faults and feel free to add in any I miss.
Handbrakes -
Symptoms: Hand brake not holding the car –
Solutions: Usually requires a overhaul of the system including: Cable, shoe, elbow or actuator and drums.
Cooling problem –
Symptoms: The car tends to over heats in traffic or driving on motor way. –
Solutions: First bleed the system, if problem persist, it could be water pump, radiator problem and thermostat at fault and this could lead to head gasket to blow!
Head Gasket –
Symptoms: Mayo like substance around the oil cap or strong smell of oil in header tank. Or pressure test the engine and check if it returning similar pressure across 4 pot (Not sure about this, someone can confirm)
Solutions: New head gasket and skim the head, while you at it might as well change the water pump, timing belt and tensioners.
Headgasket - https://www.fiatforum.com/cinquecento-seicento-guides/136702-cylinder-head-gasket-remove-refit.html
Cam belt - https://www.fiatforum.com/cinquecento-seicento-guides/100553-cam-belt-change.html
Water Pump - https://www.fiatforum.com/cinquecen...quecento-sporting-water-pump-replacement.html
Clutch cable –
Symptoms: Hard to get in gear with constant adjustment of the cable. Really when it snaps the peddle will be to the floor
Solutions: New cable, but this also implies your clutch is on the way out so start to save up prepare for a clutch change in the near future. Or possible the triangle plastic could of snapped as well.
https://www.fiatforum.com/cinquecento-seicento-guides/56093-899-clutch-cable-replacement-guide.html
Earth lead problem –
Symptoms: There are just too many, to name a few, car dies soon after it starts, headlight flickers, cars dies when brake is applied. (Again good to have more opinions on this)
Solutions: Undo earth lead; give it a rub with sand paper, then cover with Vaseline.
Rear Arch rust –
Symptoms: Your boot will start to get wet real quick causes by the hole you may find.
Solutions: Nothing you can do, get someone to weld it!
Sunroof Leak:
Symptoms: Wet passenger seat
Solution: Not an idea! Someone fill in
https://www.fiatforum.com/cinquecento-seicento-guides/101784-sunroof-removal-leak-fixes.html
Key problems:
Symptoms: Key light does not go out, and you can’t start the car
Solution: Try to start with your master key or red key, or get Mckritc Chip, this will decode the ECU
Rear Wheel Bearing
Symptoms: Squealing sound from the rear, jack the car up spin the wheel then you will hear the sound
Solution: change the rear wheel bearing; you will buy the whole unit including the hub. And must change the hub nut.
https://www.fiatforum.com/cinquecen...cinquecento-rear-hub-bearing-replacement.html
Rear bushes
Symptoms: Hard to identify, will usually hear it when driving slowly or speed bumps
Solution: Take the arm off, and cut/press the bush out. Or can create your own tools as people have one
Rear Engine mount or the gearbox mount
Symptoms: Will hear a rattle under acceleration at low speed
Solution: Chane the mount, not a diffcult job
Cam cover leak:
Symptoms: Oil everywhere on the engine block
Solution: Change the gasket and making sure both the cam and engine surface are clean!
https://www.fiatforum.com/cinquecen...val-refit-cam-cover-gasket-1108cc-engine.html
Ming
Handbrakes -
Cooling problem –
Head Gasket –
Clutch cable –
Rear Arch rust –
Sunroof Leak:
Key problems:
Rear Wheel Bearing
Rear bushes
Cam cover leak:
Ming
