Hi Guys, New to the site and need some advice. I have a S-reg sei sporting. When I bought the car the Heating wasn't working, so today I decided to drain and bleed the coolant. While doing this I removed my thermostat and to my surprise there was no spring valve just the housing. Assuming this was my problem I duly replaced with a new item.
After refilling the system I let the car come up to temp but still no heat inside the car, both pipes going to the heater cock were hot and the cock appeared to operate with the cable. I then decided to remove the pipes to flush the heater matrix in case of a blockage. The top pipe came off easily, but I have broken off the bit that the bottom hose connects to.
So my questions are
1, Can I replace only the cock or do I need the whole heater assembly
2, If the whole assembly needs replaced how do I go about it IE does the dash have to come out
3, When the new thermostat was fitted the car started overheating would a blockage in the heater matrix cause this
Thanks in advance for any help, it will be much appreciated
So my questions are
