| | Thread Tools | Search this Thread |
Posts: 71 Thanks: 2 Trader Rating: 0 | Are radius arm bushes and trailing arm bushes the same thing for a seicento sporting? Hey, from info from these forums iv found that i need to change the radius arm bushes on my sei 1.1 sporting. However all the websites and motor shops iv been to have only got trailing arm bushes. i know the trailing arm and the radius arm are different things but would trailing arm bushes do the job i need on the radius arm? if not does anyone know where i can get "radius arm" bushes from because wherever iv looked it just comes up as rear trailing arm. im quite confused. thanks
| | Quote
| | #2 |
| | Re: Are radius arm bushes and trailing arm bushes the same thing for a seicento sport rear trailing arm....its the same thing
__________________ Wanted: Novitec twin center exit b/box, or a similar styled box Hydraulic clutch mechanism, mainly the arm |
| | Quote
| | #3 | ||
Posts: 71 Thanks: 2 Trader Rating: 0 | Re: Are radius arm bushes and trailing arm bushes the same thing for a seicento sport Thanks m8 was getting rather confused... i was looking at powerflex because i dont have a press and they are finger push in but i cant really afford them i can get standard bushes for £5 on trade and its only so that itl pass m.o.t... with some hard work is it possible to fit standard bushes without a press? thanks
| | Quote
| | #4 |
| | Re: Are radius arm bushes and trailing arm bushes the same thing for a seicento sport Ive only fitted the powerflex bushes, and yes they just tap in. The originals are basterds to remove, so they'll probably be the same to fit...and without a press.....well i dont know
| | Quote
| | #5 |
Posts: 21,761 Thanks: 1071 Blog Entries: 3 Trader Rating: 1 | Re: Are radius arm bushes and trailing arm bushes the same thing for a seicento sport You could use threaded rod to make your own bush press. Cheers PD
__________________ |
| | Quote
| | #6 |
| | Re: Are radius arm bushes and trailing arm bushes the same thing for a seicento sport i tried pulling them out with a threaded bar and some nuts. the arm distorted and so did the lenght of stud bar
| | Quote
| | #7 |
| | Quote
| | #8 |
Posts: 2,089 Thanks: 47 Trader Rating: 0 | Re: Are radius arm bushes and trailing arm bushes the same thing for a seicento sport Cut/grind the inside end off the bush then a making sure you have the correctly sized tube/washer pull the entire bush through the arm including the outer metal case. You'll need M12 course studding with a minimum hardness of 10 & a large supply of nuts a grade weaker M12.
__________________ Seicento Sporting, 1.1 8v N/A, Dark grey Seicento Sporting, 1.2 8v turbo, Yellow Volvo V70 D5 Sport, 2.4 20v twin-turbo, Black |
| | Quote
| | #9 |
Posts: 2,602 Thanks: 98 Trader Rating: 0 | Re: Are radius arm bushes and trailing arm bushes the same thing for a seicento sport Cut/grind the inside end off the bush then a making sure you have the correctly sized tube/washer pull the entire bush through the arm including the outer metal case. You'll need M12 course studding with a minimum hardness of 10 & a large supply of nuts a grade weaker M12. I hate bushes. Noel
__________________ standard Sei Sporting except for colour matched ice scraper, screw driver, & steering wheel lock i.e yellow car spare alternator belt, clutch cable & bulb set, 2x overalls |
| | Quote
| | Italian Coke Can | Cinquecento / Seicento | 13 | 11-05-2008 00:51 |
| | philster | Bravo / Brava | 3 | 06-01-2008 17:12 |
| | MarkPage | Cinquecento / Seicento | 3 | 19-06-2007 22:02 |
| | dantmjones | Barchetta | 3 | 27-06-2006 12:36 |
| | rendo | Cinquecento / Seicento | 3 | 21-01-2006 09:41 |
