big john
hi folks.this my first time on fiat forum.so please be gently...! right lets get down to business.i have fiat seicento 1.1 sporting.t reg (1999). with l.p.g convertion and sports air filter...about month ago redone head gasket (followed your guide on forum.)after that the car started to cut out when drive along.with out warning.reves drop.engine cuts out.unable to start.unless unplug crank sencer.then replug back in.on 3rd try of key.it will start back up.until the next time. this has happon on both gas & petrol. i have change crank sencer before you tell me.clean and check distance between sencer and crank wheel.also change sparks,ht leads,petrol filter,clean all earth connections.i found loss connection on alternater earth.i was hopping it was that causing problems.repaired it and check batteryand alternater(12volts & 14.3volts.) still happing...! any idears would be great help.!?
